[GRASS-user] grass program compilation
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Wed May 6 14:39:15 PDT 2015
Hei Alassane,
As a general strategy, when I get this kind of compilation errors I use the locate command in order to find the file ./configure is searching for in this case:
locate ft2build.h
It will print the folder where this file can be found on your system (if the relevant module/package is installed), so you can point ./configure to that, like Eric showed. If locate does not find the required file either, you are missing the module/package and have to install it in order to meet the dependencies.
Cheers
Stefan
From: grass-user-bounces at lists.osgeo.org [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of alassane toure
Sent: 6. mai 2015 18:07
To: Vaclav Petras
Cc: GRASS user list
Subject: Re: [GRASS-user] grass program compilation
Correct!  Configure did fail ....unable to locate FreeType includes.
checking for location of FreeType includes...
checking for ft2build.h... no
configure: error: *** Unable to locate FreeType includes.
Any suggestions from this point?  Thanks!
Alassane
On Wed, May 6, 2015 at 9:59 AM, Vaclav Petras <wenzeslaus at gmail.com<mailto:wenzeslaus at gmail.com>> wrote:
On Wed, May 6, 2015 at 11:53 AM, alassane toure <atourej at gmail.com<mailto:atourej at gmail.com>> wrote:
> Group,
> I am still not making any progress compiling Grass70 on Ubuntu.  Here is where i am at:
> 1. able to run configure without any problem (with your help);
> 2. unable to compile using the following commands:
> make -j2  &&  sudo make install  &&  sudo ldconfig
> And the system response was ....
> include/Make/Vars.make:1: include/Make/Platform.make: No such file or directory
> make: *** No rule to make target `include/Make/Platform.make'.  Stop.
What was the output of configure? Perhaps it fails. Make cannot find a makefile which should be generated by configure.
Note that for running make, you need to be in the directory with the source code (as needed for configure).
> Your help is appreciated.
> Alassane
> On Tue, May 5, 2015 at 2:13 PM, alassane toure <atourej at gmail.com<mailto:atourej at gmail.com>> wrote:
>> Great! ./configure worked!   However compilation and installation did not.
>> I run the following command:
>> and the system response was:
>> I appreciate your comments/suggestions.
>> Alassane
>> On Tue, May 5, 2015 at 2:03 PM, Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>> wrote:
>>> On Tue, May 5, 2015 at 9:59 PM, alassane toure <atourej at gmail.com<mailto:atourej at gmail.com>> wrote:
>>> great!
>>> > directory
>>> please send it to the list, I am on Fedora...
>>> Markus
> grass-user mailing list
> grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150506/6a934c9c/attachment.html>
