[GRASS-user] 3 grass (v7) questions (make uninstall, r.surf.idw, copy button)
Paulo van Breugel
p.vanbreugel at gmail.com
Fri May 8 08:44:41 PDT 2015
On Fri, May 8, 2015 at 5:14 PM, Robert Kuszinger <kuszinger at giscom.hu>
wrote:
> Hello!
> I'd like to ask the following.
> *fact)* I've downloaded and compiled trunk (7.1 SVN). It was OK biut I
> don't need it anymore as I use 7.0 (SVN) instead.
> *Q)* How to remove the 7.1 installation? There is no *make uninstall*
> target ....
Not sure it is the best way, but I would simply delete the grass folder.
E.g., if you compiled it in /usr/local/grass, remove that folder. Depending
on your setup, you may have made some further changes, e.g., making a link
in /usr/bin ((e.g., using sudo ln -s /usr/local/grass7/bin/grass71
/usr/bin/), or adding a config file with the grass lib path to
/etc/ld.so.conf.d. If so, you may want to remove those too.
> *fact)* I'd like to have a copy button into the d.rast and d.vect as it
> is on many other dialogs.
> *Q)* Is it complicated to develop it for myself? Where to start? I have
> programming background. Not python, actually, but who cares...
> *fact)* r.surf.idw in 7.0.1 and 7.1 makes no interpolation. Output raster
> is the same as input and it uses 10G of memory instead of the 2G used under
> 6.4.4 on the very same raster map..
> *Q) *Is it a known bug, or is there a workaround?
> thanks! :)
> *Kuszinger Róbert Giscom Kkt.*
> *+36 30 507 0031 <%2B36%2030%20507%200031>*
> *+36 30 22 11 787*
> 1078 Budapest, Hernád u. 43
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150508/66460ec0/attachment.html>
