[GRASS-user] grass program compilation
    alassane toure
    atourej at gmail.com
    Thu May 14 14:20:42 PDT 2015
Group,
I need your help after all to compile the example code provided
"r.example".  In the Makefile, i defined MODULE_TOPDIR to point to the
location where Module.make is stored. However, when I key in "make
Makefile" (from the directory where main.c Makefile and r.example.html are
located) the response was
make: Nothing to be done for 'Makefile'
Any help to compile r.example and run it under GRASS is appreciated.
Regards,
Alassane
On Wed, May 6, 2015 at 7:35 PM, alassane toure <atourej at gmail.com> wrote:
> Thank you all for your help.  The compilation went through without any
> error!
> Now I need to compile an example program.  I hope your help will not be
> necessary.
> My regards,
> Alassane
> On Wed, May 6, 2015 at 3:39 PM, Blumentrath, Stefan <
> Stefan.Blumentrath at nina.no> wrote:
>>  Hei Alassane,
>> As a general strategy, when I get this kind of compilation errors I use
>> the locate command in order to find the file ./configure is searching for
>> in this case:
>> locate ft2build.h
>> It will print the folder where this file can be found on your system (if
>> the relevant module/package is installed), so you can point ./configure to
>> that, like Eric showed. If locate does not find the required file either,
>> you are missing the module/package and have to install it in order to meet
>> the dependencies.
>> Cheers
>> Stefan
>> *From:* grass-user-bounces at lists.osgeo.org [mailto:
>> grass-user-bounces at lists.osgeo.org] *On Behalf Of *alassane toure
>> *Sent:* 6. mai 2015 18:07
>> *To:* Vaclav Petras
>> *Cc:* GRASS user list
>> *Subject:* Re: [GRASS-user] grass program compilation
>> Correct!  Configure did fail ....unable to locate FreeType includes.
>> checking for location of FreeType includes...
>> checking for ft2build.h... no
>> configure: error: *** Unable to locate FreeType includes.
>> Any suggestions from this point?  Thanks!
>> Alassane
>> On Wed, May 6, 2015 at 9:59 AM, Vaclav Petras <wenzeslaus at gmail.com>
>> wrote:
>> On Wed, May 6, 2015 at 11:53 AM, alassane toure <atourej at gmail.com>
>> wrote:
>> > Group,
>> > I am still not making any progress compiling Grass70 on Ubuntu.  Here
>> is where i am at:
>> > 1. able to run configure without any problem (with your help);
>> > 2. unable to compile using the following commands:
>> > make -j2  &&  sudo make install  &&  sudo ldconfig
>> > And the system response was ....
>> > include/Make/Vars.make:1: include/Make/Platform.make: No such file or
>> directory
>> > make: *** No rule to make target `include/Make/Platform.make'.  Stop.
>> What was the output of configure? Perhaps it fails. Make cannot find a
>> makefile which should be generated by configure.
>> Note that for running make, you need to be in the directory with the
>> source code (as needed for configure).
>> > Your help is appreciated.
>> > Alassane
>> > On Tue, May 5, 2015 at 2:13 PM, alassane toure <atourej at gmail.com>
>> wrote:
>> >> Great! ./configure worked!   However compilation and installation did
>> not.
>> >> I run the following command:
>> >> and the system response was:
>> directory
>> >> I appreciate your comments/suggestions.
>> >> Alassane
>> >> On Tue, May 5, 2015 at 2:03 PM, Markus Neteler <neteler at osgeo.org>
>> wrote:
>> >>> On Tue, May 5, 2015 at 9:59 PM, alassane toure <atourej at gmail.com>
>> >>> great!
>> >>> > However compilation and installation did not.
>> or
>> >>> > directory
>> Stop.
>> >>> please send it to the list, I am on Fedora...
>> >>> Markus
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150514/fc2034d8/attachment.html>
