[GRASS-user] i.atcorr with ToA reflectance
Micha Silver
micha at arava.co.il
Fri May 29 06:32:24 PDT 2015
I'm trying to do atmospheric correction on some landsat 8 tiles. I have
successfully prepared ToA reflectance (with i.landsat.toar -r ).
Now when I run i.atcorr, I first get the range parameters by extracting
the actual minimum,maximum values from each band. And I set the rescale
parameter to 0,1. However this warning appears:
r.info -r lc81740392014220_toa_refl2
min=0.0749609194287782
max=0.649816591520163
i.atcorr -r input=lc81740392014220_toa_refl2 output=atcorr_test
elevation=ast_dem parameters=6S_lc81740392014220_b2.txt
range=0.0749609194287782,0.649816591520163 rescale=0,1
WARNING: Scale range length should be > 0; Using default values: [0,255]
Atmospheric correction...
and the band gets values much larger the the desired 0,1 range for
reflectance. How should this be dealt with? Is it really necessary to
set the range to the exact min/max values for each band? or can I just
choose arbitrary range values that cover the min/max for all the bands
I'm using?
(BTW, the above seems to work OK if I use ToA *radiance*, and a specific
set of range values for each band, again based on the actual min/max for
that band)
Thanks,
Micha
