[GRASS-user] r.univar: different results with different projections?
Carlos Grohmann
carlos.grohmann at gmail.com
Tue Nov 17 04:56:56 PST 2015
Hello Jörg
The area of cell shouldn't influence here. The statistics are about the
elevation values, regardless of the area represented by pixel. If I think
on the pixels as equally-spaced vector points, after projection they won't
be equally-spaced anymore, but the number of points won't change. So the
mean of their values (and stddev, etc) shouldn't change as well.
regards
Carlos
On Tue, Nov 17, 2015 at 5:15 AM, Robl Jörg Christian <Joerg.Robl at sbg.ac.at>
wrote:
> Dear Carlos,
> I’m not an expert for projections.
> However, on Lat/Long WGS84 the actual area of cells decline from the
> equator towards the poles.
> Thus, I would expect that cell values near the poles have “more weight”
> using Lat/Long WGS84 than using an equal area projection.
> Near the poles I don’t understand how the values for extent and resolution
> should be correct (equal area), except there is a huge distortion (very
> likely for a cylindrical projection)!
> Are there really 21600 cols with a nsres = 1178 m at the north and south
> pole. I would call this a huge distortion.
> As a test, I would calculate the statistics for a smaller area centered at
> the equator. I would expect that the results are very similar comparing the
> lat/long and the reprojected dataset.
> Regards Jörg
> *Von:* grass-user [mailto:grass-user-bounces at lists.osgeo.org] *Im Auftrag
> von *Carlos Grohmann
> *Gesendet:* Montag, 16. November 2015 23:32
> *Cc:* GRASS user list
> *Betreff:* Re: [GRASS-user] r.univar: different results with different
> projections?
> Hello Cesar
> That was weird, so I tested it again. The number of cells is the same for
> both projections, but the values differ. This must be related to
> reprojecting.
> To me, they shouldn't de different, since a nearest neighbor should
> preserve the original values. I'm not really comfortable with this, as I'm
> not sure I can trust the stats after projecting.
> best
> Carlos
> GRASS 7.1.svn (latlong):~ > g.region raster=gdem_etopo1_ice -pa
> projection: 3 (Latitude-Longitude)
> zone: 0
> datum: wgs84
> ellipsoid: wgs84
> north: 90N
> south: 90S
> west: 180W
> east: 180E
> nsres: 0:01
> ewres: 0:01
> rows: 10800
> cols: 21600
> cells: 233280000
> GRASS 7.1.svn (latlong):~ > r.univar map=gdem_etopo1_ice -ge percentile=100
> n=233280000
> null_cells=0
> cells=233280000
> min=-10803
> max=8333
> range=19136
> mean=-1892.40422534294
> mean_of_abs=2644.91906490912
> stddev=2649.98339302808
> variance=7022411.98332463
> coeff_var=-140.032629262802
> sum=-441460057688
> first_quartile=-4286
> median=-2457
> third_quartile=214
> percentile_100=8333
> GRASS 7.1.svn (eqarea):~ > g.region -p
> projection: 99 (Equal Area Cylindrical)
> zone: 0
> datum: wgs84
> ellipsoid: wgs84
> north: 6363885.33192604
> south: -6363885.33192604
> west: -20037508.34278924
> east: 20037508.34278924
> nsres: 1178.49728369
> ewres: 1855.32484655
> rows: 10800
> cols: 21600
> cells: 233280000
> GRASS 7.1.svn (eqarea):~ > r.univar map=gdem_etopo1_ice -ge percentile=100
> n=233280000
> null_cells=0
> cells=233280000
> min=-10803
> max=8333
> range=19136
> mean=-2382.28934158093
> mean_of_abs=2845.10169015775
> stddev=2508.93105538271
> variance=6294735.0406638
> coeff_var=-105.315966939504
> sum=-555740457604
> first_quartile=-4544
> median=-3285
> third_quartile=93
> percentile_100=8333
> On Mon, Nov 16, 2015 at 7:43 PM, César Augusto Ramírez Franco <
> caesarivs at gmail.com> wrote:
> Carlos,
> 2015-11-16 14:47 GMT-05:00 Carlos Grohmann <carlos.grohmann at gmail.com>:
> GRASS 7.1.svn (base_maps):~ > g.region -p raster=gdem_etopo1_ice
> cells: 233280000
> GRASS 7.1.svn (base_maps):~ > r.univar map=gdem_etopo1_ice -ge
> percentile=100
> cells=58320000
> cells=233280000
> Notice how the number of pixels differs, that's the reason the
> statistics are not the same, I don't get why the region has a different
> number of pixels than the raster itself in the original latlong
> projection... I think that's the root of the issue
> *César Augusto Ramírez Franco*
> Laboratorio de Sistemas Complejos Naturales
> Escuela de Geociencias - Facultad de Ciencias
> Universidad Nacional de Colombia - Sede Medellín
> Teléfono: (57-4) 430 9369 - 300 459 6085
> http://labscn-unalmed.github.io/
> Prof. Carlos Henrique Grohmann
> Institute of Energy and Environment - Univ. of São Paulo, Brazil
> - Digital Terrain Analysis | GIS | Remote Sensing -
> http://carlosgrohmann.com
> http://orcid.org/0000-0001-5073-5572
> ________________
> Can’t stop the signal.
________________
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151117/731e25cf/attachment.html>
