[GRASS-user] v.rast.stats error
Martin Landa landa.martin at gmail.com
Fri Nov 20 08:33:23 PST 2015
2015-11-20 17:28 GMT+01:00 Lorenzo Bottaccioli <lorenzo.bottaccioli at gmail.com>:
> I'have created the vector with r.to.vect, before I have liked
> v.exeternel.out to the PostGIS DB. If I run v.what.rast there is no problem
> but I believe that the results are different.
OK, now I understand, v.what.rast operates on points/centoids,
v.rast.stats on areas. There is something wrong with areas. Generally
speaking I cannot suggest to use PostGIS links in GRASS for production
work. Use native format instead.
Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
