[GRASS-user] location/mapset naming restrictions
Glynn Clements
glynn at gclements.plus.com
Mon Nov 30 17:40:10 PST 2015
Panagiotis Mavrogiorgos wrote:
> Are there any restrictions to the location/mapset names?
They may not contain any of the characters:
or space, DEL (code 127/0x7F), any control character or any 8-bit
character.
[source: lib/gis/legal_name.c]
Also, because map, mapset and location names are used directly as file
and/or directory names, they may not contain any character which is
prohibited in a filename by the underlying OS. On Windows, this
includes:
[source: try entering any of these characters when renaming a file or
directory on Windows.]
The OS may also impose other restrictions (e.g. you typically can't
have a file or directory named "." or ".." although the "." character
isn't itself prohibited).
> I just found out that if you use a numeric mapset (e.g. 2014_123) you have
> to use single quotes in mapcalc expressions.
Which names are legal and which names can be used in r.mapcalc without
quoting are different. E.g. a "-" character (minus, hyphen, dash) is
legal in a map, mapset or location name, but r.mapcalc requires the
name to be quoted, otherwise it will be interpreted as a subtraction.
> e.g the following example will
> raise an error:
> r.mapcalc expression="foo=R1 at 2014_123"
> results in:
> syntax error, unexpected INTEGER, expecting VARNAME or NAME
An unquoted name consists of a sequence of characters other than
space, control characters, or any of:
[source: raster/r.mapcalc/mapcalc.l, definition of "N" (line 97).]
*However*: it may not have a prefix which is a valid integer or
floating-point literal (which is why your example above generates an
error), as those take precedence over names.
A quoted name can contain any character other than the quote character
itself. Note that quoted names aren't always maps (or mapsets or
locations); they can also be used for variables if you feel you have
to use a name which isn't valid as an unquoted name.
