[GRASS-user] grass71_trunk: error on access gui
Eugenio Trumpy
frippe12573 at hotmail.com
Fri Oct 2 07:39:51 PDT 2015
it is just what I did.
I tried both distclean and erase all the grass7_trunk directory and I started again
with new svn code. I recompiled without errors.
Those are my config lines:
CFLAGS="-O2 -Wall" LDFLAGS="-s" ./configure --enable-largefile=yes --with-nls --with-cxx --with-readline --with-pthread --with-proj-share=/usr/local/share/proj/ --with-geos=/usr/local/bin/geos-config --with-wxwidgets --with-cairo --with-opengl-libs=/usr/include/GL --with-freetype=yes --with-freetype-includes="/usr/include/freetype2/" --with-postgres=yes --with-postgres-includes="/usr/include/postgresql" --with-sqlite=yes --with-mysql=yes --with-mysql-includes="/usr/include/mysql" --with-odbc=no --with-liblas=yes --with-liblas-config=/usr/bin/liblas-config --with-proj-share=/usr/share/proj --with-geos=/usr/bin/geos-config --with-netcdf
No errors on make && make install.
Starting grass71 I have the choice of the location and mapset,
then it crash with the highlighted errors.
Any idea?
Eugenio
> Date: Fri, 2 Oct 2015 15:28:28 +0200
> From: mlennert at club.worldonline.be
> To: frippe12573 at hotmail.com; neteler at osgeo.org
> CC: grass-user at lists.osgeo.org
> Subject: Re: [GRASS-user] grass71_trunk: error on access gui
> On 02/10/15 15:17, Eugenio Trumpy wrote:
> > Hi Markus,
> > yes I did it.
> Maybe you have to erase your previous installation before installing the
> newly compiled one:
> https://lists.osgeo.org/pipermail/grass-dev/2015-September/076473.html
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151002/2892f550/attachment.html>
