[GRASS-user] Organizing locations and mapsets on NFS for teams
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Sun Oct 4 06:23:04 PDT 2015
Hi Markus,
Thanks for your reply.
Yes, I was referring to the "Using GRASS GIS locations in a network"/"Student machine(s)" section. I overlooked the "NFS read-only reason" for this solution...
Do you (or anyone else) have a smart solution for keeping your locations on NFS tidy? Are you and your colleagues only very disciplined or do you have a kind of data care taker who cleans up the GRASS DB regularly and maybe archives expired projects?
Do you use specific naming conventions (esp. for mapsets but maybe also maps)? We copied the convention used on the wiki-page to name locations by CRS, but I am less sure what to do when it comes to mapsets... Here, I was considering using prefixes like "G_" for all mapsets of general interest (probably "GT_" for TGIS-mapsets) followed by a thematic name / keyword, "P_" followed by project name for project mapsets, and "U_" followed by user name for user mapsets... So at least these conceptually different mapset types group / order logicaly...
And how do you maintain the PERMANENT mapset(s) on NFS. Does only the creator of the location use / modify it? Are there any solutions for doing that in a collaborative approach (which might be used for other mapsets too)? I mean in terms of access rights...
Do you use a metadata repository to make it transparent for everybody what data is in what mapset?
Sorry for the bunch of questions. Using GRASS already helps a lot to have and keep the (growing amounts of) data well structured, but a description of recommended practices or field-proven solution might help users to get even more out of it...
Kind regards
Stefan
-----Original Message-----
From: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] On Behalf Of Markus Neteler
Sent: 4. oktober 2015 09:01
To: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>
Cc: grass-user grass-user (grass-user at lists.osgeo.org) <grass-user at lists.osgeo.org>
Subject: Re: [GRASS-user] Organizing locations and mapsets on NFS for teams
On Thu, Oct 1, 2015 at 12:19 PM, Blumentrath, Stefan <Stefan.Blumentrath at nina.no> wrote:
> The solution described here:
> https://grasswiki.osgeo.org/wiki/Location_and_Mapsets with common
> GRASS DB on NFS linked into users home directory is somewhat sexy in
> order to keep the “user mapsets” out of the common GRASS GIS DB. The
> drawback however is, that users explicitly have to switch between the
> two GRASS DBs if they want to share data on NFS, if I understood the consequences correctly.
Are you sure about this? Do you refer to the section "Student machine(s)"?
In my group, we simply have all in /grassdata/ which is on NFS (actually with a big BeeGFS device behind).
Works nicely.
Markus
