[GRASS-user] problem with t.rast.mapcalc (grass71 daily ubuntu	14.04)
    Veronica Andreo
    veroandreo at gmail.com
    Tue Oct  6 12:17:01 PDT 2015
Hola Leo,
The problem with basenames was fixed in r66308 (
https://trac.osgeo.org/grass/changeset/66308). I've been using basename
equal to strds name and works as expected.
Enjoy!
Vero
El sep 9, 2015 3:38 PM, "Leonardo Hardtke" <leohardtke at gmail.com> escribió:
> Thaks
> If it is a bug, I should fill a bug report so that some developer can fix
> it!
> Cheers
> 2015-09-09 15:17 GMT-03:00 Veronica Andreo <veroandreo at gmail.com>:
>> Hi Leo,
>> Yes, I had the same problem some time ago and the solution was to change
>> the name, as you mentioned...
>> Maybe a bug? Dunno :)
>> Cheers,
>> Vero
>> El sep 9, 2015 3:05 PM, "Leonardo Hardtke" <leohardtke at gmail.com>
>> escribió:
>>> Dear GRASS users (and developers?!),
>>> I'm facing a problem with an expression in the t.rast.mapcalc module...
>>> t.rast.mapcalc inputs=QA_mask,ndvi,ndvi_smooth_spacetime
>>> expression="if(QA_mask==0,ndvi,ndvi_smooth_spacetime)" output=ndvi_fixed
>>> basename=ndvi_fixed
>>> It throws the following error:
>>> Starting temporal sampling...
>>> Starting mapcalc computation...
>>> Invalid map
>>> <MOD13Q1.A2009017.h12v12.005.2009035110230_01_4326_smooth_spacetime_0>
>>> Parse error
>>> ERROR: parse error
>>> ERROR: Error while mapcalc computation
>>> The QA_mask maps are:
>>> QA_mask_01|PERMANENT|2009-01-01 00:00:00|2009-01-17 00:00:00
>>> QA_mask_02|PERMANENT|2009-01-17 00:00:00|2009-02-02 00:00:00
>>> The ndvi_smooth_spacetime maps are:
>>> ndvi_smooth_spacetime_0|PERMANENT|2009-01-17 00:00:00|2009-02-02 00:00:00
>>> ndvi_smooth_spacetime_1|PERMANENT|2009-02-02 00:00:00|2009-02-18 00:00:00
>>> The ndvi maps are
>>> MOD13Q1.A2009001.h12v12.005.2009019145228_01_4326|PERMANENT|2009-01-01
>>> MOD13Q1.A2009017.h12v12.005.2009035110230_01_4326|PERMANENT|2009-01-17
>>> M
>>> As you see, there is no such a map like..
>>> I guess the module is mixing ndvi (a temporal dataset) with
>>> _smooth_spacetime... the second part of the name....
>>> I know it work ok by renaming the ndvi_smooth_spacetime by something
>>> else... but... is this a bug or shoul I use more '`" to protect names !?
>>> Thanks!
>>> Dr. Leonardo A. Hardtke
>>> Laboratorio de Teledetección y S.I.G.
>>> Centro Nacional Patagónico (CONICET)
>>> Bvd. Brown 2825, 9120
>>> Puerto Madryn, Chubut, Argentina
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151006/a7410338/attachment.html>
