[GRASS-user] Splitting a location across several disks
    Dylan Beaudette
    dylan.beaudette at gmail.com
    Wed Oct  7 15:02:38 PDT 2015
It has been a while, but glad to be back on GRASS-user.
I am working on a project that involves a significant storage dilemma: try
and fit most of the files into a 500 Gb SSD for blazing-fast I/O, or fall
back to a standard but higher capacity disk drive.
Would it be possible to store "derived" data into a mapset that is on
standard disk, while the "source" data reside in another mapset, stored on
the SSD?
In other words, is it OK for a location to contain several mapsets that
don't "live" on the same physical disk. It seems like it should work (via
symlink), but I would like to see if there are any caveats that I should be
aware of.
Also, is the NULL file compression code ready for production use?
https://trac.osgeo.org/grass/ticket/2750
Thanks!
Dylan
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151007/17dad63a/attachment.html>
