[GRASS-user] Query vector type has problems
    Vaclav Petras
    wenzeslaus at gmail.com
    Fri Oct  9 17:30:08 PDT 2015
On Thu, Jul 30, 2015 at 6:06 AM, Andres Kuusk <andres at to.ee> wrote:
> Vector commands v.what.vect and v.distance do not fill the attribute
> column of a point vector.
> I created small test vectors, a vector map 'varea' of area type which has
> an area polygon, and a vector map of points 'vpoints' - 191 GPS way-points,
> 135 of which are inside the polygon.
> The command
> v.what.vect map=vpoints column=aid query_map=varea query_column=aid
> returns:
> Finding nearest features...
> Update vector attributes...
> 191 categories - no nearest feature found
> The same result I get using v.distance:
> v.distance from=vpoints to=varea dmax=0. upload=to_attr column=aid
> to_column=aid
Hi Andres,
please try the latest trunk (at least r66460 [1, 2]). Can you please try to
create a Bash script or a Python script which would prepare some data or
use data from NC basic/small Location [2] and run v.what.vect in the same
way as you were running it? In this way we can see if the recent changes
provide expected results.
Thanks,
Vaclav
[1] https://trac.osgeo.org/grass/changeset/66460
[2] https://trac.osgeo.org/grass/ticket/2734#comment:2
[3] http://grass.osgeo.org/download/sample-data/
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151009/827618d4/attachment.html>
