[GRASS-user] External Database and projections
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Wed Oct 14 07:09:00 PDT 2015
Hi Lorenzo,
What do you mean with a «distributed infrastructure”?
Do you want to make the rasters available via WWW or in your company/institution?
There are other options to share data than PostGIS… Within an organization your GRASS GIS database on NFS would be a much, much more efficient one.
For WWW-publishing WCS is an option…
Anyway, writing copies of your raster maps to DB (PostGIS) – if that is a fix requirement - is less of a problem (if they are not too heavy), than writing to DB, reading from DB for processing in GRASS and writing result back to DB…
If your aim is to add “zonal statistics” to a vector layer in PostGIS I would do the raster operation in GRASS and then join the result to PG…
Cheers
Stefan
From: Lorenzo Bottaccioli [mailto:lorenzo.bottaccioli at gmail.com]
Sent: 14. oktober 2015 15:44
To: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>
Cc: Dylan Beaudette <dylan.beaudette at gmail.com>; Markus Neteler <neteler at osgeo.org>; GRASS user list <grass-user at lists.osgeo.org>
Subject: Re: [GRASS-user] External Database and projections
Hello,
Thanks for your suggestion. The point is that I need do develop a distributed infrastructure hence I need to store the raster in to a DB after the creation. Once I have created the raster immages I'll need to do some simple multiplication and I thought to do them with r.mapcalc. Then I'll use a vector map in order to extract the values of the raster.
So i think I'll have to use inevitably a DBMS to store the raster images produced with grass. I'm I wright?
Tnx again regards
Lorenzo
2015-10-08 8:40 GMT+02:00 Blumentrath, Stefan <Stefan.Blumentrath at nina.no<mailto:Stefan.Blumentrath at nina.no>>:
Hi Dylan,
Yes, r.external and r.external.out works pretty well with TGIS. Here is a discussion in this regards I had mainly with Sören…
https://lists.osgeo.org/pipermail/grass-user/2013-December/069377.html
I have used r.external/r.external.out in TGIS for a while (with compressed GeoTiffs, btw you should not pre-define the predictor for LZW-compression as long as you are not sure that all raster maps are of the same type (CELL/FCELL/DCELL)), but went back to using internal GRASS format, because external links are a bit tricky to use on NFS and from different OS (or if data is moved):
https://trac.osgeo.org/grass/ticket/2660
Another minor (and often neglectable) drawback of using r.external is that file names and map names get out of sync if you rename maps. g.rename renames only the GRASS internal map name (modifies the link) the underlying data file is not touched and stays with the old name…
Cheers
Stefan
From: Dylan Beaudette [mailto:dylan.beaudette at gmail.com<mailto:dylan.beaudette at gmail.com>]
Sent: 8. oktober 2015 00:17
To: Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>>
Cc: Blumentrath, Stefan <Stefan.Blumentrath at nina.no<mailto:Stefan.Blumentrath at nina.no>>; GRASS user list <grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>>
The use of r.external makes a lot of sense when dealing with very large files. Does the use of "external" files work as expected in all of the new t.* modules?
Thanks,
Dylan
On Wed, Oct 7, 2015 at 12:09 PM, Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>> wrote:
On Wed, Oct 7, 2015 at 12:55 PM, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no<mailto:Stefan.Blumentrath at nina.no>> wrote:
> My suggestion is to not use PostGIS for big rasters, unless you have to,
> because you want to use the data in a specific application for example.
Note r.external and r.external.out of GRASS GIS 7 for avoiding data duplication:
https://grass.osgeo.org/grass70/manuals/r.external.html
https://grass.osgeo.org/grass70/manuals/r.external.out.html
Here an example:
# register (rather than import) a GeoTIFF file in GRASS GIS:
r.external input=terra_lst1km20030314.LST_Day.tif output=modis_celsius
# define output directory for files resulting from subsequent calculations:
r.external.out directory=$HOME/gisoutput/ format="GTiff"
# perform calculations (here: extract pixels > 20 deg C)
# store output directly as GeoTIFF file, hence add the .tif extension:
r.mapcalc "warm.tif = if(modis_celsius > 20.0, modis_celsius, null() )"
# cease GDAL output connection and turn back to write standard GRASS
raster files:
r.external.out -r
# use the result elsewhere
qgis $HOME/gisoutput/warm.tif
Best
Markus
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151014/cf80e372/attachment-0001.html>
