[GRASS-user] Reprojection of raster maps in various platforms: projected coordinates are different
    Uttam Kumar
    uttamsinha09 at gmail.com
    Fri Oct 16 13:15:49 PDT 2015
Thank you so much.
Yes the datum should have been NAD83. This is perfect. Please summarize me
how did you do this transformation from sinusoidal to Lambert Azimuthal
Equal Area?
I have all my source images in sinusoidal projection in a location called
"Landsat_sinu".
I want to create a target locatoin "Landsat_laea"? I tried using the
default option in GRASS GUI and the options I selected was
1.) *Select coordinate system parameters from a list*
2.) Projection code: *laea*
3.) Datum with associated ellipsoid:
Central parallel: *30*
Central Meridian: *-96*
False easting: *0*
False northing: *0*
4.) Datum code: *nad83*
5.) Select from the list of datum transformation: *1 used in whole nad83
region*
+proj=laea
+lat_0=30
+lon_0=-96
+x_0=0
+y_0=0
+no_defs
+a=6378137
+rf=298.257222101
+towgs84=0.000,0.000,0.000
to_meter=1
+datum=nad83
Finish.
Is everything ok with this for the below (required) target definition?
*PROJ.4 : '+proj=laea +lat_0=30 +lon_0=-96 +x_0=0 +y_0=0 +datum=NAD83
+units=m +no_defs '*
Looks like at some point I am making a small mistake.
On Wed, Oct 14, 2015 at 4:52 PM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> [Please keep conversations on the list]
> On 14/10/15 23:19, Uttam Kumar wrote:
>> _
>> _
>> _*This information is for the original data (Source):*_
>> *PROJ.4 : '+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6371007.181
>> +b=6371007.181 +units=m +no_defs '*
>> Coordinate System is:
>> PROJCS["Sinusoidal",
>>      GEOGCS["GCS_Unknown",
>>          DATUM["Unknown",
>>              SPHEROID["S_Unknown",6371007.181,0.0]],
>>          PRIMEM["Greenwich",0.0],
>>          UNIT["Degree",0.0174532925199433]],
>>      PROJECTION["Sinusoidal"],
>>      PARAMETER["False_Easting",0.0],
>>      PARAMETER["False_Northing",0.0],
>>      PARAMETER["longitude_of_center",0.0],
>>      UNIT["Meter",1]]
>> Origin = (-10801805.197699999436736,4130102.079069999977946)
>> Pixel Size = (30.000000000000000,-30.000000000000000)
>> _This information is for the destination data (Target):_*
> In your first mail you said:
> Lambert Azimuthal Equal Area, Datum: WGS84
> but here the datum is NAD83.
> Using your projection info, I get almost exactly the same results in GRASS
> as you report from ENVI:
> On 08/10/15 21:36, Uttam Kumar wrote:> Reprojected in ENVI (Lambert
> Azimuthal Equal Area, Datum: WGS84)
> > Corner Coordinates:
> > Upper Left  (-2265106.681W, 1064601.383N)
> > Lower Left  (-2265106.681W,  830181.383N)
> > Upper Right (-1960126.681W, 1064601.383N)
> > Lower Right (-1960126.681W,  830181.383N)
> GRASS 7.0.1 (test_LAEA):~ > v.info -g Image_Boundary_box
> north=1064601.38274499
> south=830176.771464028
> east=-1960125.15283348
> west=-2265106.68066176
> Don't have the time now to explore the exact differences, but either it's
> a question of definition of the bounding box, or it possibly be a question
> of which specific NAD83 transformation parameters were used.
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151016/b47b3429/attachment.html>
