[GRASS-user] r.contour failing?
Markus Neteler neteler at osgeo.org
Mon Oct 19 02:42:30 PDT 2015
On Mon, Oct 19, 2015 at 11:35 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Il 19/10/2015 11:30, Markus Neteler ha scritto:
>> The problem is to "guess" how much memory resources are available
>> which change continuously (i.e. RAM is naturally static but its
>> allocation not).
> sure - perhaps taking the total memory as an upper bound could mitigate
> at least the most serious cases.
In case it would be RAM + SWAP.
But to my limited knowledge it is not possible to easily know the
available memory on at least Windows (what I remember from past
discussions here).
>> Just check the "history" file of the mapset. Some previously issued
>> command will have set the computational region.
>> A candidate might be a g.region vector=vmap with an additional
>> (unneeded) res=value call (maybe from "Processing"?).
> right - interestingly enough, the history does not seem to be visible in
> the current version of the grass qgis plugin - going to explore this.
thanks - it would be great to have it also there.
ciao
Markus
