[GRASS-user] add superscript to units on a legend
Veronica Andreo veroandreo at gmail.com
Mon Oct 19 09:08:26 PDT 2015
I had the same problem some time ago, and just kept the "^" in
µg/m^3 because i didn't find superscript format nor in d.text (or the gui
to add text) neither in ps.map...
But maybe in your case you can use mg/ha to avoid the ^?
Cheers,
Vero
2015-10-18 21:41 GMT-03:00 Davies, Kalu <kalu.davies at jcu.edu.au>:
> Hi…
> I’m trying to create a map of soil carbon stocks so I would like the
> legend to display the units as "Mg C per ha" however I would prefer that
> the “per ha” was represented as “ha^-1” but obviously without the “^” and
> using superscript instead.
> I have found how to set the units in r.support, however I cannot figure
> out how to format them with the superscript?
> many thanks...
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151019/5ee05990/attachment.html>
