[GRASS-user] Something wrong: Reprojection of raster maps in various platforms: projected coordinates are different
Uttam Kumar
uttamsinha09 at gmail.com
Tue Oct 20 10:08:41 PDT 2015
I have been trying for a long time. Something wrong is going on. I
appreciate if you can correct me.
I have all my source images in sinusoidal projection in a location called
"Landsat_sinu".
My target locatoin is "Landsat_laea" I tried using the default option in
GRASS GUI as follows:
1.) *Select coordinate system parameters from a list*
2.) Projection code: *laea*
3.) Datum with associated ellipsoid:
Central parallel: *30*
Central Meridian: *-96*
False easting: *0*
False northing: *0*
4.) Datum code: *nad83*
5.) Select from the list of datum transformation: *1 used in whole nad83
region*
+proj=laea
+lat_0=30
+lon_0=-96
+x_0=0
+y_0=0
+no_defs
+a=6378137
+rf=298.257222101
+towgs84=0.000,0.000,0.000
to_meter=1
+datum=nad83
Finish.
Is everything ok with this for the below (required) target definition?
**PROJ.4 : '+proj=laea +lat_0=30 +lon_0=-96 +x_0=0 +y_0=0 +datum=NAD83
+units=m +no_defs '**
Looks like at some point I am making a small mistake. I must get this as
the projected coordinates.
* north=1064601.38274499 south=830176.771464028 east=-1960125.15283348
west=-2265106.68066176*
Any help is appreciated.
Uttam.
On Wed, Oct 14, 2015 at 4:52 PM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> [Please keep conversations on the list]
> On 14/10/15 23:19, Uttam Kumar wrote:
>> _
>> _
>> _*This information is for the original data (Source):*_
>> *PROJ.4 : '+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6371007.181
>> +b=6371007.181 +units=m +no_defs '*
>> Coordinate System is:
>> PROJCS["Sinusoidal",
>> GEOGCS["GCS_Unknown",
>> DATUM["Unknown",
>> SPHEROID["S_Unknown",6371007.181,0.0]],
>> PRIMEM["Greenwich",0.0],
>> UNIT["Degree",0.0174532925199433]],
>> PROJECTION["Sinusoidal"],
>> PARAMETER["False_Easting",0.0],
>> PARAMETER["False_Northing",0.0],
>> PARAMETER["longitude_of_center",0.0],
>> UNIT["Meter",1]]
>> Origin = (-10801805.197699999436736,4130102.079069999977946)
>> Pixel Size = (30.000000000000000,-30.000000000000000)
>> _This information is for the destination data (Target):_*
> In your first mail you said:
> Lambert Azimuthal Equal Area, Datum: WGS84
> but here the datum is NAD83.
> Using your projection info, I get almost exactly the same results in GRASS
> as you report from ENVI:
> On 08/10/15 21:36, Uttam Kumar wrote:> Reprojected in ENVI (Lambert
> Azimuthal Equal Area, Datum: WGS84)
> > Corner Coordinates:
> > Upper Left (-2265106.681W, 1064601.383N)
> > Lower Left (-2265106.681W, 830181.383N)
> > Upper Right (-1960126.681W, 1064601.383N)
> > Lower Right (-1960126.681W, 830181.383N)
> GRASS 7.0.1 (test_LAEA):~ > v.info -g Image_Boundary_box
> Don't have the time now to explore the exact differences, but either it's
> a question of definition of the bounding box, or it possibly be a question
> of which specific NAD83 transformation parameters were used.
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151020/5bc85ec0/attachment-0001.html>
