[GRASS-user] External raster from PostGIS
Lorenzo Bottaccioli
lorenzo.bottaccioli at gmail.com
Thu Oct 22 09:03:51 PDT 2015
Hi Markus,
How do I implement such command in GRASS GIS? I have tried with r.external
because I have done the same thing with v.external. I'have tried as well
with r.in.gdal but notthing. If i use v.in.ogr I can import vectors from
PostGIS.
Lorenzo
2015-10-22 17:55 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> On Thu, Oct 22, 2015 at 12:49 PM, Lorenzo Bottaccioli
> <lorenzo.bottaccioli at gmail.com> wrote:
> > Hello,
> > I'm tryng to import a raster file sotred in PostGIS with r.external but i
> > cannot select the db. If I try with r.in.gdal and i connect to the db I
> > can't see the table.
> Can you please post the full command? (omitting the password if given
> there)
> Is it similar to what's given in
> https://trac.osgeo.org/gdal/wiki/frmts_wtkraster.html#a3.2-Readingrasterdatafromthedatabase
> I would like to add an example to the manual page but do not have a PG
> installation containing a raster map.
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151022/9d3330fe/attachment.html>
