[GRASS-user] Problems running g.gui.gcp
Anna Petrášová
kratochanna at gmail.com
Fri Oct 23 04:37:22 PDT 2015
On Oct 23, 2015 6:04 AM, "Johannes Radinger" <johannesradinger at gmail.com>
wrote:
> On Fri, Oct 23, 2015 at 11:19 AM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
>> On 23/10/15 10:56, Johannes Radinger wrote:
>>> On Fri, Oct 23, 2015 at 10:17 AM, Moritz Lennert
>>> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
wrote:
>>> On 22/10/15 16:25, Johannes Radinger wrote:
>>> Dear GRASS users,
>>> Today I wanted to try the georectification tool g.gui.gcp in
>>> GRASS 7 for
>>> the first time. I was basically following the description on the
>>> GRASS
>>> wiki (https://grasswiki.osgeo.org/wiki/Georeferencing). In
>>> particular, I
>>> have a photograph from my camera with known reference points
which I
>>> load into an unprojected XY location. My target location should
>>> also be
>>> a XY location as the picture is taken from a "virtual"
coordinate
>>> system. Inside my target XY-location I try to open g.gui.gcp and
>>> select
>>> raster, and the location and mapset where my photograph is
>>> stored. When
>>> I want to click next I get following error/message: "You must
>>> select a
>>> valid location and mapset in order to continue" and I can't
>>> proceed with
>>> the rectification. Just this GUI message appears, no
>>> error/warning in
>>> the grass console etc. I am puzzled how to interpret that? What
>>> is wrong
>>> with the location/mapset? The mapset I've selected is existing
>>> (I can
>>> select it from the dropdown menu). I tried to select any other
>>> location/mapset but receive always the same message.
>>> Georectification is for georeferencing to a projected system. It
>>> does not make sense to georeference to an XY-location.
>>> I see two options for you:
>>> - Import you image directely into the target region and use r.region
>>> to adjust its boundary coordinates
>>> - Define your own projection system to fit your needs.
>>> So far as I understand georectification and orthorectification in
>>> particular is to rectify a picture/photo/image based on spatially
>>> defined ground control points which might not be done by just adjusting
>>> the boundary coordinates. BTW I also tried the European LAEA coordinate
>>> system (EPSG 3035) as a target location which is not working either here
>>> in my machine/setup (same message as already mentioned). Here
https://www.dropbox.com/s/snjzd8eu7b8115k/2015-10-22%2015.26.30.jpg?dl=0)
>>> you can find a a photo (*.jpg) which is an "areal" photo with known 3d
>>> coordinates for the single points (ground control points). I think this
>>> example clarifies and illustrates what I intend to do and why the target
>>> system can also be a XY location in my opinion. A rectification of this
>>> image should make the lines of the grid more or less parallel. Or do I
>>> get something completely wrong?
>> Actually, I was wrong: I don't get any complaint trying to use g.gui.gcp
to georectify from XY to XY. So there seems to be an issue with your XY
locations.
>> Have you tried recreating the locations from scratch ?
> Your results look really reasonable.... that's what I was looking for...
> Actually, both XY locations are created from scratch (via the location
wizzard)
> I get following output for both XY locations:
> g.proj -p
> XY location (unprojected)
> I tried to start the GCP manager from within different other locations
(e.g. laea, datum: etrs89) and selecting different source location (e.g.
WGS84)....however I always get the same message. So I guess this is not
specifically related to my location but rather to the GCP manager/WX GUI?
As I don't get an error message it is difficult to judge what is going
wrong in my case...
> I just looked up the source code and the error message seems to be
related to follwoing line:
https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/gui/wxpython/gcp/manager.py#L399
> As far as I understand, this error message is only given if no
location/mapset is provided; however that is not the case here. Maybe my
selection of the location/mapset via the GUI does not get parsed
further....?
> Strange that orthorectification from one XY to antother XY location works
on other machines but not on mine.
> PS: As an important side note: I am working on Ubuntu which is installed
on a virtual machine (VMWare) on our server. I remotely connect to this
virtual machine via RDP
I noticed you have strange version of wxpython. Any chance you could test
on machine with version 2.8.12.0 or a stable 3 version?
Anna
>> Moritz
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151023/da9c01cd/attachment.html>
