[GRASS-user] External raster from PostGIS
Lorenzo Bottaccioli
lorenzo.bottaccioli at gmail.com
Fri Oct 23 05:43:35 PDT 2015
Hi Markus,
I did not try with any command in the command line, I'have just tried with
the GUI of r.in.gdal selecting database. Can you give a suggestion for the
use of "source=" option in the command line of r.external in order to
select data from a PostGIS db?
Tnx
Lorenzo
2015-10-22 18:34 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> Hi Lorenzo,
> On Thu, Oct 22, 2015 at 6:03 PM, Lorenzo Bottaccioli
> <lorenzo.bottaccioli at gmail.com> wrote:
> > Hi Markus,
> > How do I implement such command in GRASS GIS? I have tried with
> r.external
> > because I have done the same thing with v.external. I'have tried as well
> > with r.in.gdal but notthing. If i use v.in.ogr I can import vectors from
> > PostGIS.
> I would just like to the command to use. And the error message.
> Perhaps we see why it fails.
> Did you use "source=..." of r.external?
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151023/91918784/attachment.html>
