[GRASS-user] External raster from PostGIS
Lorenzo Bottaccioli
lorenzo.bottaccioli at gmail.com
Fri Oct 23 07:40:06 PDT 2015
Hi Markus,
I have tried to read the manual of r.external but is not clear how it works
with DB, is very clear how it works with files. Using the GUI of r.external
and connecting to the db i cannot see the raster map.
I've used v.external with DB and that one was easy.
Regards
lorenzo
2015-10-23 16:05 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> Hi Lorenzo
> On Oct 23, 2015 2:43 PM, "Lorenzo Bottaccioli" <
> lorenzo.bottaccioli at gmail.com> wrote:
> > Hi Markus,
> > I did not try with any command in the command line, I'have just tried
> with the GUI of r.in.gdal selecting database. Can you give a suggestion for
> the use of "source=" option in the command line of r.external in order to
> select data from a PostGIS db?
> I was referring to r.external.
> Best
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151023/a6618387/attachment.html>
