[GRASS-user] homebrew and GRASS
Rainer M Krug
Rainer at krugs.de
Thu Oct 29 09:02:53 PDT 2015
Doc Robinson <doc.robinson at utoronto.ca> writes:
> hi again,
Hi
I forward this to the grass-user list as these are relevant questions.
> I am gearing up to install homebrew then the various versions of GRASS.
> I have already installed XQuartz, but I noticed that on one page with
> instructions they list it as being installed after homebrew...does it
> matter?
I can't think of any reason why it should matter.
> On the Apple app store the version of Xcode is 7.1 while the example on
> http://coolestguidesontheplanet.com/installing-homebrew-os-x-yosemite-10-10-package-manager-unix-apps/
> is 6.3 is home brew sensitive to the version?
In general, you should always use the newest version of Xcode - I never
had problems with this and
--8<---------------cut here---------------start------------->8---
brew doctor
--8<---------------cut here---------------end--------------->8---
even warns you if a newer version is available.
> no rush...thanks in advance
No problem.
Just be aware that the grass recipe from homebrew does not work at the
moment, but the osgeo4mac recipes[1] grass-64 is working, grass-70
produces errors but I guess you can install it with --without-gui.
There is also my port of the osgeo recipe for 7.0 to install 7.1 (-HEAD
only) at https://github.com/rkrug/homebrew-head-only, which presumably
has the same problems as grass-70
Cheers,
Rainer
> On 2015-10-07 12:09 PM, Rainer M Krug wrote:
>> Envoyé de mon iPhone
>>> Le 7 oct. 2015 à 17:56, Doc Robinson <doc.robinson at utoronto.ca> a
>>> écrit :
>>> Hi I saw your post on the GRASS list about using homebrew to
>>> install both 7.0 and 7.1 under both Yosemite and El Capitan.
>>> I have just taken delivery of macmini with Yosemite on it. I do not
>>> intend to upgrad to El Capitan unless there is an absolute need for
>>> me to.
>> Unless you have a really good reason, I would upgrade to El Capitan.
>> Most of the problems occur in upgrades - not new installations.
>>> My question is related to homebrew and installing GRASS 6.4.x. Have
>>> you done that or have you just done the 7.x installs on your
>>> system?
>> I have 6.4 installed as well.
>>> It will be my first try at using homebrew.
>> In my opinion (with my Linux background) homebrew plays an important
>> in the Apple universe. I try to install everything using homebrew and
>> if makes many things much easier for me.
>> But one thing I learned: try to avoid mixing homebrew with the
>> standard apple packages- this can cause difficult to identify
>> problems.
>> Don't hesitate to come back with further questions. Possibly cc the
>> grass user mailinglist as this might be if general interest.
>> Cheers,
>> Rainer
>>> thanks in advance.
>>> -- Regards, Doc
> Vincent B. Robinson |
>>> Department of Geography | E-Mail: doc.robinson at utoronto.ca
>>> University of Toronto | Voice: (905)828-5299 at Mississauga
>>> | Fax: (905)828-5273 Mississauga, Ontario | Canada L5L
>>> 1C6 |
Footnotes:
[1] https://github.com/OSGeo/homebrew-osgeo4mac
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151029/14ea5b69/attachment.sig>
