[GRASS-user] ERROR: Error reading raster data for row 210 of <cumRAD>
umberto.minora
umberto.minora at unimi.it
Thu Sep 3 07:43:38 PDT 2015
I am experiencing this problem. If I run in GRASS 7.0.0 (2015):
r.mapcalc new_cumRAD = cumRAD + altavaltellina_rad10_250_05.00
I receive:
"cumRAD" is the result of previous calculation, where I summed all the
hourly global radiation maps (derived with "r.sun.hourly" function) one by
one with a Python script. Everything worked fine until I got stucked at
julianday 250 hour 04).
The problem seems to be in the "cumRAD" variable, but I cannot seem to
understand the reason of the error message.
In addition, this is my Python code:
# cumulative global radiation from julian day 152 to 259 (included)
import grass.script as grass
day_month=[range(152,182),range(182,213),range(213,244),range(244,260)] #
list julian days from 1 Jun to 16 Sept divided per month
hour = range(24) # list the hours of the day (0 to 23)
hour = ['{:02d}'.format(x) for x in hour] # change the length to 2
grass.mapcalc('cumRAD = $globrad',
globrad = 'altavaltellina_rad7'+ '_'+ str(day_month[0][0])+ '_'+
hour[0]+ '.00')
for m in xrange(len(day_month)):
for d in day_month[m]:
for h in hour:
grass.mapcalc('new_cumRAD = cumRAD + $globrad',
globrad = 'altavaltellina_rad'+ str(m+7)+ '_'+ str(d)+ '_'+ h+ '.00',
overwrite = True) # WARNING: the "+7" in "str(m+7)" should refer to
month 6 (June) but it's 7 here due to a previous mistake in the calculation
print 'altavaltellina_rad'+ str(m+7)+ '_'+ str(d)+ '_'+ h+ '.00 was added
succesfully!'
grass.run_command('g.rename',
rast=('new_cumRAD','cumRAD'),
overwrite = True)
View this message in context: http://osgeo-org.1560.x6.nabble.com/ERROR-Error-reading-raster-data-for-row-210-of-cumRAD-tp5222503.html
Sent from the Grass - Users mailing list archive at Nabble.com.
