[GRASS-user] exporting map display
Vincent Bain
bain at toraval.fr
Wed Sep 9 09:43:35 PDT 2015
I might miss something : when I run the command I get this error :
ERROR: No graphics device selected. Use d.mon to select graphics device.
Is it necessary to first start a graphics monitor (which one ?) and how
is it possible to populate this display via the GUI layer manager (and
not commands like d.vect, d.rast...)
Sorry, I guess my issue is stupid!
Vincent.
Le mercredi 09 septembre 2015 à 12:27 -0400, Anna Petrášová a écrit :
> Hi Vincent,
> if I understand your use case correctly, d.to.rast should do what you
> want. It works in GUI. But maybe I am misunderstanding.
> On Wed, Sep 9, 2015 at 9:52 AM, Vincent Bain <bain at toraval.fr> wrote:
> Thanks you Anna,
> unfortunately I understand d.to.rast cannot handle the content
> of the
> gui default display frame, which is the only display that
> allows me to
> tweak transparency.
> My temporary fix was to :
> -"set computational region from display extent" ;
> -press the button "save display to graphic file", outputting
> my
> composition in a source.png file ;
> -then write down a short shell script in this flavor :
> eval `g.region -g`
> IFS=,
> size=($(identify -format %w,%h source.png))
> gdal_translate -gcp 0 0 $w $n -gcp ${size[0]} 0 $e $n -gcp
> ${size[0]}
> ${size[1]} $e $s source.png target.tif
> gcps2wld.py target.tif>target.tfw
> This method is certainly not much accurate but it provides me
> a fast
> georeferenced snapshot of a map composition.
> Yours,
> Vincent
