[GRASS-user] v.colors and raster color table.
Moritz Lennert
mlennert at club.worldonline.be
Fri Sep 11 09:37:28 PDT 2015
On 10/09/15 17:04, Aldo CLERICI wrote:
> I’m having problem in assigning a raster color table to a vector map.
> g.copy vector=roads,roads_copia (no color table)
> v.colors map=roads_copia raster=slope (a color table is assigned)
> v.colors map=roads_copia raster=soils (no color table assigned)
> It seems that if the raster map contains integer values the colors are
> not assigned, but surely there is some other reason I don’t understand.
> Is there a place where the criteria of defining colors from a raster map
> to be assigned to a vector map are explained?
This is a known issue:
https://trac.osgeo.org/grass/ticket/2556
but it would help if you could add your experience to that ticket.
Moritz
