[GRASS-user] trimming color table
Paulo van Breugel p.vanbreugel at gmail.com
Fri Sep 18 02:39:46 PDT 2015
On 18-09-15 10:06, Glynn Clements wrote:
> Paulo van Breugel wrote:
>> When creating a new map based on an existing using r.mapcalc, the color
>> table of the old map is used for the new map. However, if the new map
>> only contains a subset of the values of the old map, how can I trim the
>> color table so it only contains color definitions for the values present
>> in the new map? Any easy (automatic) way to do this? Note, this is
>> probably only useful for integer (category) maps.
> There isn't an automatic way to do this. The simplest way is probably
> along the lines of
> 	r.colors.out map | command | r.colors map rules=-
> where "command" is a grep/sed/etc command which filters the rules.
Thanks. I wrote a small Python script which basically does that, so I
can run something like 'trim(map)' with map being an integer /
categorical map.
