[GRASS-user] i.spec.sam: problem installing
    Carmine Massarelli
    carmine.massarelli at ba.irsa.cnr.it
    Mon Sep 21 08:31:44 PDT 2015
Dear,
I have same problem installing /i.spec.sam/ on grass 7.0.1 and/or 7.1.
I saw that the compilation failed
(/https://grass.osgeo.org/addons/grass7/logs/summary.html/), I would
like to know if in the future there could be news or updates.
I would like to use the addon with CASI-sensor iperspectral images.
Thanks
FYI
In GRASS 7.0.1 I receive this error (In Ubuntu 14.04 64bit):
/Fetching <i.spec.sam> from GRASS-Addons SVN repository (be patient)...//
//D1/5: grass.script.core.start_command(): g.message//
//message=Compiling...//
//D1/5: G_set_program_name(): g.message//
//D2/5: G_file_name(): path =//
///mnt/xxx/PERMANENT//
//Compiling...//
//In file included from main.c:25:0://
//global.h:14:1: error: unknown type name ‘MAT’//
// extern MAT *A;//
//global.h:15:1: error: unknown type name ‘VEC’//
// extern VEC *b, *Avector;//
//global.h:1:0: error: unterminated #ifndef//
// #ifndef __GLOBAL_H__//
//main.c:26:29: fatal error: meschach/matrix.h: File o//
//directory non esistente//
// #include <meschach/matrix.h>//
//compilation terminated.//
//make: *** [OBJ.x86_64-pc-linux-gnu/main.o] Errore 1//
//D1/5: grass.script.core.start_command(): g.message -e//
//message=Compilation failed, sorry. Please check above error//
//messages.//
//ERROR: Compilation failed, sorry. Please check above error messages./
Carmine
Un allegato HTML � stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150921/1237c035/attachment.html>
