[GRASS-user] Need help in reprojecting raster images
sajid pareeth
spareeth at gmail.com
Tue Sep 22 23:59:54 PDT 2015
Hi Uttam
If I understand you correctly you want to reproject a landsat image from
sinusoidal to laea projection!!
You dont have to manually set the bounding box while reprojecting a raster,
as GRASS will take care of it.
First you create a new location and mapset with desired output projection ,
which in this case is Lamberts Azimuthal Equal Area.
Then get into this mapset, use the following r.proj command.
r.proj location*=input_location* mapset=*input_mapset* input=*input_raster
name* output=
*output_raster*
More details here: https://grass.osgeo.org/grass70/manuals/r.proj.html
If you then need to set your working area to a particular bounding box, use
g.region
g.region raster=*output_raster*
regards
Sajid
On Tue, Sep 22, 2015 at 11:07 PM, Uttam Sinha <uttamsinha09 at gmail.com>
wrote:
> Hi All,
> I have a set of Landsat images in Sinusoidal Projection, WGS84 Datum. I
> know the north, south, east and west extent of the boundary of the image.
> I want to reproject the image to Lamberts Azimuthal Equal Area, WGS84
> Datum. I do not know what will be the coordinates of the north, south, east
> and west bounds in this projection.
> 1.) How do I convert upper left coordinates and bottom right coordinates
> of Sinusoidal Projection to Lamberts Azimuthal Equal Area to create a new
> destination Location?
> 2.) How do I reproject the images from Sinusoidal to Lamberts without
> georeferencing the image at source location (in sinusoidal projection)
> Appreciate any reply.
> Uttam.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150923/c0e989a9/attachment.html>
