[GRASS-user] Migrating to a different database engines in Grass 7.0.1RC2
Paul Shapley p.shapley at gmail.com
Sun Sep 27 10:38:20 PDT 2015
Hello Grass Users,
I would like to know why and where grass stores old database connection
parameters set with 'db.connect' and 'db.login'. this is not in the 'VAR'
file in the PERMANENT directory, I often switch between PostGIS and SQLite
data but even if i add a new connection it seems to retrieve a three year
old connection parameter and i dont want to keep having to create a new
'mapset' every time i change. Should i go back to 6.4 stable or is there
another solution?
Many thanks,
*Paul J. Shapley *MSc CGeog (GIS) FRGS
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150927/ebda799f/attachment.html>
