[GRASS-user] problem with python scripting
Leonardo Hardtke leohardtke at gmail.com
Tue Apr 5 00:02:46 PDT 2016
Hi Paulo and thanks for the answer... but It gives me a very similar error
if I write the full flag.... (The only difference is TypeError... str if I
use 'o' and int if I use 'overwrite'.... )
 gscript.mapcalc('endmember_rstr.1 = null()', flags="overwrite")
ERROR: output map <endmember_rstr.1> exists. To overwrite, use the
       --overwrite flag
  File "<stdin>", line 1, in <module>
  File "/usr/lib/grass70/etc/python/grass/script/raster.py", line 103, in
mapcalc
    quiet=quiet, verbose=verbose, overwrite=overwrite)
  File "/usr/lib/grass70/etc/python/grass/script/core.py", line 516, in
write_command
    return handle_errors(returncode, returncode, args, kwargs)
  File "/usr/lib/grass70/etc/python/grass/script/core.py", line 312, in
handle_errors
    returncode=returncode)
  File "/usr/lib/grass70/etc/python/grass/exceptions/__init__.py", line 68,
in __init__
    msg = _("Module run %s %s ended with error") % (module, code)
TypeError: 'int' object is not callable
Thanks for your help!
2016-04-05 16:56 GMT+10:00 Paulo van Breugel <p.vanbreugel at gmail.com>:
> On 05-04-16 08:53, Leonardo Hardtke wrote:
> Dear users,
> I am writing a script and I'm having problems with the flags for mapcalc
> gscript.mapcalc('endmember_rstr.1 = null()', flags="o")
> If  you are using GRASS 7.+, the overwrite flag should be written in full,
> i.e.,
>        --overwrite flag
> mapcalc
> write_command
> handle_errors
> 68, in __init__
> TypeError: 'str' object is not callable
> with other modules flags are working as I expect, like....
> gscript.run_command("g.region", flags="p")
> projection: 1 (UTM)
> zone:       -20
> datum:      wgs84
> ellipsoid:  wgs84
> north:      5326556.02809
> south:      5228355.32592
> west:       290546.512535
> east:       444008.446334
> nsres:      30.00326984
> ewres:      30.0081998
> rows:       3273
> cols:       5114
> cells:      16738122
> Am I missing something?
> Thanks!
> Dr. Leonardo A. Hardtke
> Laboratorio de Teledetección y S.I.G.
> Centro Nacional Patagónico (CONICET)
> Bvd. Brown 2825, 9120
> Puerto Madryn, Chubut, Argentina
> grass-user mailing listgrass-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160405/0585c456/attachment-0001.html>
