[GRASS-user] problem with python scripting
Leonardo Hardtke
leohardtke at gmail.com
Tue Apr 5 00:11:43 PDT 2016
Thanks Paulo and Sören for helping!
overwrite=True made the trick! Is this documented somewhere and I just
missed it??? Or should I fill a ticket?
Leo
2016-04-05 17:06 GMT+10:00 Sören Gebbert <soerengebbert at googlemail.com>:
> Please try gscript.mapcalc(expr... , overwrite=True)
> Am 05.04.2016 09:02 schrieb "Leonardo Hardtke" <leohardtke at gmail.com>:
>> Hi Paulo and thanks for the answer... but It gives me a very similar
>> error if I write the full flag.... (The only difference is TypeError... str
>> if I use 'o' and int if I use 'overwrite'.... )
>> gscript.mapcalc('endmember_rstr.1 = null()', flags="overwrite")
>> ERROR: output map <endmember_rstr.1> exists. To overwrite, use the
>> --overwrite flag
>> Traceback (most recent call last):
>> File "<stdin>", line 1, in <module>
>> File "/usr/lib/grass70/etc/python/grass/script/raster.py", line 103, in
>> mapcalc
>> quiet=quiet, verbose=verbose, overwrite=overwrite)
>> File "/usr/lib/grass70/etc/python/grass/script/core.py", line 516, in
>> write_command
>> return handle_errors(returncode, returncode, args, kwargs)
>> File "/usr/lib/grass70/etc/python/grass/script/core.py", line 312, in
>> handle_errors
>> returncode=returncode)
>> File "/usr/lib/grass70/etc/python/grass/exceptions/__init__.py", line
>> 68, in __init__
>> msg = _("Module run %s %s ended with error") % (module, code)
>> TypeError: 'int' object is not callable
>> Thanks for your help!
>> 2016-04-05 16:56 GMT+10:00 Paulo van Breugel <p.vanbreugel at gmail.com>:
>>> On 05-04-16 08:53, Leonardo Hardtke wrote:
>>> Dear users,
>>> I am writing a script and I'm having problems with the flags for mapcalc
>>> gscript.mapcalc('endmember_rstr.1 = null()', flags="o")
>>> If you are using GRASS 7.+, the overwrite flag should be written in
>>> full, i.e.,
>>> --overwrite flag
>>> in mapcalc
>>> write_command
>>> handle_errors
>>> 68, in __init__
>>> TypeError: 'str' object is not callable
>>> with other modules flags are working as I expect, like....
>>> gscript.run_command("g.region", flags="p")
>>> projection: 1 (UTM)
>>> zone: -20
>>> datum: wgs84
>>> ellipsoid: wgs84
>>> north: 5326556.02809
>>> south: 5228355.32592
>>> west: 290546.512535
>>> east: 444008.446334
>>> nsres: 30.00326984
>>> ewres: 30.0081998
>>> rows: 3273
>>> cols: 5114
>>> cells: 16738122
>>> Am I missing something?
>>> Thanks!
>>> Dr. Leonardo A. Hardtke
>>> Laboratorio de Teledetección y S.I.G.
>>> Centro Nacional Patagónico (CONICET)
>>> Bvd. Brown 2825, 9120
>>> Puerto Madryn, Chubut, Argentina
>>> grass-user mailing listgrass-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160405/eb865e40/attachment-0001.html>
