[GRASS-user] v.db.connect.all - errors
Carlos Grohmann carlos.grohmann at gmail.com
Wed Apr 13 15:17:03 PDT 2016
here is the output:
GRASS 7.0.3 (latlong):~ > db.connect -p
driver: sqlite
database: /Volumes/MacintoshHD2/grassdata/latlong/base_maps/sqlite/sqlite.db
schema:
group:
thanks
On Wed, Apr 13, 2016 at 6:58 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Apr 13, 2016 at 10:33 PM, Carlos Grohmann
> <carlos.grohmann at gmail.com> wrote:
> > Hi all
> > I just tried to change all the vector maps of one location from DBF to
> > SQLite, following this page:
> https://grasswiki.osgeo.org/wiki/Convert_all_GRASS_6_vector_maps_to_GRASS_7
> > these are the steps:
> > # first rebuild topology for all vector maps in current mapset
> > v.build.all
> > # define new default DB connection (switch from DBF to SQLite)
> > db.connect -d
> Can you here please run
> db.connect -p
> to see what it picked up? (should be sqlite).
> > # transfer all attribute tables from DBF to SQLite and clean old DBF
> tables
> > v.db.reconnect.all -cd
> > steps 1 and 2 work fine, but #3 doesn't v.db.reconnect.all -c
> > dbmi: db_list_databases() not implemented
> > ERROR: Unable to list databases. Try to define correct connection
> settings
> >        by db.login.
> I think that this error got reported in the past on MacOSX:
> So it would be important to know where it comes from (hence my
> question above to get an idea).
> Markus
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
________________
Can’t stop the signal.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160413/32821b71/attachment.html>
