[GRASS-user] temporal dataset : register maps from other mapsets
Martin Landa
landa.martin at gmail.com
Sun Apr 17 03:54:06 PDT 2016
Hi Soren,
2016-04-17 12:32 GMT+02:00 Sören Gebbert <soerengebbert at googlemail.com>:
> However, in "THEORY" you can set the database connection for each mapset to
> point to a single database. Then you must set the TGIS_DISABLE_MAPSET_CHECK
> environment variable, so that the temporal framework does allow that map
> layers from different mapset can be registered in a single space time
> dataset. I have not tested this and there are no gunittests available yet
> that check for this hidden feature.
thanks for detailed explanation! Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
