[GRASS-user] temporal dataset : register maps from other mapsets
Sören Gebbert
soerengebbert at googlemail.com
Sun Apr 17 04:12:03 PDT 2016
I decided to use a mapset specific variable, since this will affect the
temporal database of this mapset and therefore all processes related to
this mapset. Hmmm ... there are pros an cons for booth solutions, but i
will stick with the current one. :)
Cheers
Soeren
Am 17.04.2016 13:05 schrieb "Martin Landa" <landa.martin at gmail.com>:
2016-04-17 12:56 GMT+02:00 Sören Gebbert <soerengebbert at googlemail.com>:
> Set it with:
> g.gisenv set="TGIS_DISABLE_TIMESTAMP_WRITE=True
probably better would be environment variable (export) rather than
GRASS variable? Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
-------------- nächster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160417/4f343fe5/attachment.html>
