[GRASS-user] Import sqlite table using db.in.ogr
Moritz Lennert
mlennert at club.worldonline.be
Wed Aug 3 08:42:26 PDT 2016
On 03/08/16 17:31, Markus Neteler wrote:
> Hi,
> note the differences:
> On Wed, Aug 3, 2016 at 3:52 PM, Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
> On 03/08/16 12:35, Johannes Radinger wrote:
> db.in.ogr
> input=/media/grassgis_data/GRASS_locations/nc_spm_08_grass7/PERMANENT/sqlite/sqlite.db
> --> nc_spm_08_grass7
> v.db.connect -p streams
> Vector map <streams> is connected by:
> layer <1/streams> table <streams> in database
> </data/GRASS/DATA7/nc_spm_08/PERMANENT/dbf/> through driver <dbf>
> with key <cat>
> --> nc_spm_08
> The latter is for G6, not G7... just to avoid confusion.
Well, it's my set for GRASS7, but I guess somewhen way back in time I
must have taken the GRASS6 version and run v.build.all in it to use it
in GRASS7... ;-)
Anyhow, Johannes: what does 'v.db.connect -p streams' give you ?
Moritz
