[GRASS-user] Import sqlite table using db.in.ogr
Moritz Lennert mlennert at club.worldonline.be
Thu Aug 4 03:56:44 PDT 2016
On 04/08/16 09:46, Markus Metz wrote:
> On Wed, Aug 3, 2016 at 11:04 PM, Johannes Radinger
> <johannesradinger at gmail.com> wrote:
>> Hi all,
>> the database is the original sqlite database the ships with the the NC
>> grass7 location (nc_spm_08_grass7). I want to import a single table (e.g
>> 'streams') from that NC grass7 database (source, sqlite) into my new
>> location (target) using db.in.ogr. As far as I understand, for the module
>> db.in.ogr the database scheme of the target location should not be of
>> relevance?! Interestingly, the database scheme (either sqlite, dbf etc) of
>> the source db/table is not explicitly specified in db.in.ogr?!
> OGR recognizes the driver automatically.
>> Have you tried to import e.g. the 'streams' table of the PERMANENT mapset of
>> any NC grass7 sample location from within any other location?
>> Here the example from the manual:
>> db.in.ogr input=/path/to/sqlite.db db_table=census_raleigh
>> output=census_raleigh
> this example can not work because input is replaced by db_table if
> db_table is given. It seems that db.in.ogr works only with dbf and
> only if input is the full path to the dbf file, db_table must not be
> set. The fix would be easy: delete lines 74, 75 from db.in.ogr.py.
Right (sorry, saw this message after sending the other).
Maybe the best would be to rename these parameters to:
database=
and
table=
where database could be a directory for file-based tables (e.g. dbf) ?
Just like the input/layer parameters in v.in.ogr.
Moritz
