[GRASS-user] Error trying to run grass from python script/command line in Windows
Jose M
soloninguno at hotmail.com
Thu Aug 4 18:29:12 PDT 2016
Hi Vaclav,
Thanks for your suggestions
I already tried obtaining the gisbase from the binary but got the same error, so i then switch to the shorthand way (besides, instaling grass through the Osgeo4w doesn't create a grass70.bat in the
C:\OSGeo4W\apps\grass\grass-7.0.4 folder, the bat seems to be only created using the standalone grass installers).
Using this way I'm getting the same stacktrace.
script.run_command('g.list', flags='m', type='raster')
Running the os.environ shows me several variables, the more relevants I suppose are
'PYTHONPATH': 'C:\\OSGeo4W\\apps\\grass\\grass-7.0.4\\etc\\python'
'GISBASE': 'C:\\OSGeo4W\\apps\\grass\\grass-7.0.4'
'GISRC': 'c:\\users\\Carl\\appdata\\local\\temp\\tmprv4iwf'
'GIS_LOCK': '5156'
'GRASS_PYTHON': 'python.exe'
'GRASS_ADDON_BASE': 'C:\\Users\\Carl\\AppData\\Roaming\\GRASS7\\addons'
'PATH': ''C:\\Windows\\SYSTEM32;C:\\Windows;C:\\Windows\\SYSTEM32\\WBEM;C:\\Program Files (x86)\\GDAL;C:\\Python27;C:\\Python27;C:\\Python27\\Scripts;C:\\OSGeo4W\\apps\\grass\\grass-7.0.4\\bin;C:\\OSGeo4W\\apps\\grass\\grass-7.0.4\\scripts;C:\\OSGeo4W\\apps\\grass\\grass-7.0.4\\extrabin;C:\\OSGeo4W\\apps\\grass\\grass-7.0.4\\lib',
'GDAL_DRIVER_PATH': 'C:\\Program Files (x86)\\GDAL\\gdalplugins'
'GDAL_DATA': 'C:\\Program Files (x86)\\GDAL\\gdal-data'
'SAGA_MLB': 'C:\\Saga\\modules'
'GDAL_HOME': 'C:\\Program Files (x86)\\GDAL'
'PYTHON_HOME': 'C:\\Python27'
'SAGA_HOME': 'C:\\Saga'
I forgot to mention in the first mail that before getting the stack trace a popup appear saying this
Microsoft Visual C++ Runtime Library
Program
C:\OSGeo4W\apps\grass\grass-7.0.4\bin\g.gisenv.EXE
R6034
An application has made an attempt to load the C runtime library incorrectly.
Please contact the application's support team for more information.
And then another popup with a g.gisenv.exe application error printing the error 0x0000142.
What i discover is that if I remove gdal from PATH environment, the error change to "iconv.dll missing" but with a similar stacktrace
grass.exceptions.CalledModuleError: Module run None ['g.gisenv', '-n'] ended with error
Process ended with non-zero return code -1073741515. See errors in the (error) output.
Maybe has something to do that my OS is Win 7 x64 ? I choose the x32 as my system wide python is x32.
Thanks!
De: Vaclav Petras <wenzeslaus at gmail.com>
Enviado: jueves, 04 de agosto de 2016 09:37 p.m.
Para: Jose M
Cc: grass-user at lists.osgeo.org
Asunto: Re: [GRASS-user] Error trying to run grass from python script/command line in Windows
On Thu, Aug 4, 2016 at 7:50 PM, Jose M <soloninguno at hotmail.com<mailto:soloninguno at hotmail.com>> wrote:
gisbase = r'C:\OSGeo4W\apps\grass\grass-7.0.4'
os.environ['GISBASE'] = gisbase
likely unrelated but I suggest to use the way specified in the manual, i.e. obtaining the GISBASE value from the binary:
# query GRASS GIS itself for its GISBASE
startcmd = [grass7bin, '--config', 'path']
try:
p = subprocess.Popen(startcmd, shell=False,
stdout=subprocess.PIPE, stderr=subprocess.PIPE)
out, err = p.communicate()
except OSError as error:
sys.exit("ERROR: Cannot find GRASS GIS start script"
" {cmd}: {error}".format(cmd=startcmd[0], error=error))
if p.returncode != 0:
sys.exit("ERROR: Issues running GRASS GIS start script"
" {cmd}: {error}"
.format(cmd=' '.join(startcmd), error=err))
gisbase = out.strip(os.linesep)
https://grass.osgeo.org/grass72/manuals/libpython/script.html#module-script.setup
gscript.run_command('g.list -m type=raster')
Unrelated, but this is not guaranteed to work. Use the syntax:
gscript.run_command('g.list', flags='m', type='raster')
And this is the stacktrace I'm getting
C:\test>setupgrass.py
File "C:\test\setupgrass.py", line 20, in <module>
File "C:\OSGeo4W\apps\grass\grass-7.0.4\etc\python\grass\script\core.py", line 393, in run_command
ps = start_command(*args, **kwargs)
File "C:\OSGeo4W\apps\grass\grass-7.0.4\etc\python\grass\script\core.py", line 356, in start_command
if debug_level() > 0:
File "C:\OSGeo4W\apps\grass\grass-7.0.4\etc\python\grass\script\core.py", line 1519, in debug_level
_debug_level = int(gisenv().get('DEBUG', 0))
File "C:\OSGeo4W\apps\grass\grass-7.0.4\etc\python\grass\script\core.py", line 935, in gisenv
s = read_command("g.gisenv", flags='n')
File "C:\OSGeo4W\apps\grass\grass-7.0.4\etc\python\grass\script\core.py", line 446, in read_command
return handle_errors(returncode, stdout, args, kwargs)
File "C:\OSGeo4W\apps\grass\grass-7.0.4\etc\python\grass\script\core.py", line 313, in handle_errors
returncode=returncode)
Process ended with non-zero return code -1073741502. See errors in the (error) output.
According to my Internet search, -1073741502 means STATUS_DLL_INIT_FAILED - DLL Initialization Failed. So perhaps the installation is somehow broken or the paths are not set right. You can try
print os.environ
after init() call to see how the paths are set.
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160805/62a3763e/attachment-0001.html>
