[GRASS-user] grass run_command within python/grass script
Laurent C. lrntct at gmail.com
Fri Aug 12 16:30:52 PDT 2016
Hello,
You try to pass a string as an argument to run_command, which will not work.
If you want to change the input, change that string only:
for m in maps:
    grass.run_command('r.in.gdal', input=m, output=m)
or, as in your example:
grass.run_command('r.in.gdal', input=sys.argv[5], output='your_map')
For command line parsing, I recommend using GRASS parser or argparse.
For string formatting, use .format() instead of %, which is deprecated.
(https://docs.python.org/2/library/stdtypes.html#str.format)
Laurent
2016-08-11 15:04 GMT-05:00 alassane toure <atourej at gmail.com>:
> Group,
> I am running a grass-python script but when i replace a variable argument
> within the command the script does not work....
> The following works...
> input='/home/alassane/Data/SanbornCD/tile/newconstr_mask.tif',
> output='construction')
> But not this...
> command="'r.in.gdal', input='"+sys.argv[5]+"', output='construction'"
> print 'r.in.gdal command argument... = %s\n ' % command
> grass.run_command(command)
> r.in.gdal command argument... = 'r.in.gdal',
> The following also works...
> command ="/home/alassane/Programs/gdal/demclass1"+" "+infile1+" "+infile2+"
> "+sys.argv[3]+" "+outfile
> os.system(command)
> Your help is appreciated.
> Regards,
> Alassane
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
