[GRASS-user] GRASS at the 12th International Conference on Hydroinformatics
Thomas Adams tea3rd at gmail.com
Fri Aug 12 21:28:23 PDT 2016
Hi Laurent,
Not sure what I'm doing wrong; I followed the installation using:
pip install itzi
which placed itzi here...
/home/teaiii/.local/lib/python2.7/site-packages/itzi
Running: itzi run parameter_file_name ... gives me this...
GRASS 7.0.3 (nc_spm_08_grass7):~/grass/data > itzi run test
itzi: command not found
I guess itzi was not installed where it should go or is my PATH not right?
Tom
On Fri, Aug 12, 2016 at 7:09 PM, Laurent C. <lrntct at gmail.com> wrote:
> Hello,
> This message to let you know that I'll give a talk called "A GRASS GIS
> module for 2D superficial flow simulations" at the 12th International
> Conference on Hydroinformatics that will be held from 21 to 26 of
> august in Incheon, Korea. The goal is basically to present Itzï
> (https://www.itzi.org/), a new superficial flow model that uses GRASS
> as a back-end.
> If any other GRASS user will be present at this event, I'll be glad to
> meet.
> Of course, I'll be happy if anyone give a try at the software and give
> me some feed back.
> Cheers,
> Laurent
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Thomas E Adams, III
1724 Sage Lane
Blacksburg, VA 24060
1 (513) 739-9512 (cell)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160813/d7e2c08d/attachment.html>
