[GRASS-user] g.list in a python script
    Markus Neteler
    neteler at osgeo.org
    Mon Aug 15 14:56:40 PDT 2016
On Sat, Aug 13, 2016 at 7:30 PM, Micha Silver <micha at arava.co.il> wrote:
> In a python script, I am doing g.list to get a certain set of rasters, then
> r.series to sum the values. I find that g.list adds a newline character at
> the end of the string, and that causes r.series to fail. I've added the
> python rstrip('\n') to avoid this.
> Is that the expected output from g.list?
> Here's the code that works:
> rast_list = gscript.read_command('g.list', type='rast', separator='comma',
> pattern='ims_*')
> rast_list = rast_list.rstrip('\n')
> gscript.run_command('r.series', input=rast_list, output=ttl_ims_precip,
> method='sum', overwrite=True)
> Without the "rstrip" call, then r.series fails.
Would this interface to g.list work better?
https://grasswiki.osgeo.org/wiki/GRASS_Python_Scripting_Library#Interface_to_listing_maps_.28g.list.29
Markus
