[GRASS-user] Can't load NetCDF after 7.0.4 upgrade
    Markus Neteler
    neteler at osgeo.org
    Tue Aug 16 06:28:14 PDT 2016
On Tue, Aug 16, 2016 at 3:25 PM, Ken Mankoff <mankoff at gmail.com> wrote:
> On 2016-08-15 at 22:07, Ken Mankoff <mankoff at gmail.com> wrote:
>> Hi GRASS list,
>> I recently upgraded to 7.0.4 and can no longer open NetCDF files. I
>> re-installed several components at the time of the upgrade, so this
>> may be a gdal or other software error too. I'm not sure how to debug
>> this, and hope someone here can help.
>> I now get the following error:
>> ERROR 4: No such file or directory
>> ERROR: Unable to open datasource
>>        <NETCDF:foo.nc:var>
> This is fixed by compiling gdal 1 with "--with-complete" and then grass with gdal1 not the default gdal2:
> brew install gdal --with-complete
> brew install grass-70 --with-netcdf --with-gdal-1
Glad you found a solution. Please consider to add some notes here:
https://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX_using_homebrew
Markus
