[GRASS-user] Pan sharpen Worldview-2 imagery
Nikos Alexandris
nik at nikosalexandris.net
Wed Aug 17 14:37:29 PDT 2016
William:
>>>>> The link you provided documents how to use g.extension for installing
>>>>> python scripts in GRASS 7.3. In particular, it uses the 'url=....'
>>>>> argument to specify a link to a zip file. I am using the stable version
>>>>> of GRASS 7.0 that is installed with Ubuntu 16.01. In that version, the
>>>>> 'url=...' argument is not available. Is there an alternative way to
>>>>> install your extension in GRASS 7.0?
Nikos:
>>>> Can you get GRASS' source code (any version 7.x) and follow steps in
>>>> https://svn.osgeo.org/grass/grass-addons/README?
William:
>>> version of GRASS 7.0 that is installed with Ubuntu 16.01. In that
>>> version, the 'url=...' argument is not available. Is there an
>>> alternative way to install your extension in GRASS 7.0?
Moritz:
>> Download the extension to your machine, unzip it, go into the directory
>> and then run
>> make MODULE_TOPDIR=/path/to/your/grass/installation
>> You have to have the grass-dev package installed for it to work.
William:
> I have tried installing from the unzipped directory using the following
> for grass installation path, and with the following errors:
> make MODULE_TOPDIR=/usr/lib/grass70
> GISRC=/usr/lib/grass70/demolocation/.grassrc70 GISBASE=/usr/lib/grass70
> PATH="/usr/lib/grass70/bin:/usr/lib/grass70/bin:/usr/lib/grass70/scripts:$PATH"
> PYTHONPATH="/usr/lib/grass70/etc/python:/usr/lib/grass70/gui/wxpython:$PYTHONPATH"
> LD_LIBRARY_PATH="/usr/lib/grass70/bin:/usr/lib/grass70/bin:/usr/lib/grass70/scripts:/usr/lib/grass70/lib:/usr/lib/grass70/lib:"
> LC_ALL=C g.parser -t i.worldview.toar.py | sed s/\"/\\\\\"/g | sed
> 's/.*/_("&")/' >
> /usr/lib/grass70/locale/scriptstrings/i.worldview.toar_to_translate.c
> /bin/sh: 1: cannot create
> /usr/lib/grass70/locale/scriptstrings/i.worldview.toar_to_translate.c:
> Directory nonexistent
> ERROR: Variable 'LOCATION_NAME' not set
> /usr/lib/grass70/include/Make/ScriptRules.make:28: recipe for target
> '/usr/lib/grass70/locale/scriptstrings/i.worldview.toar_to_translate.c'
> failed
> make:
> [/usr/lib/grass70/locale/scriptstrings/i.worldview.toar_to_translate.c]
> Error 2 (ignored)
Alright. Are you inside a GRASS session? Try it out. I always compile my
add-ons once inside a GRASS session.
Best, Nikos
