[GRASS-user] bug 3057
Greg Minshall minshall at acm.org
Thu Aug 25 03:02:40 PDT 2016
hi.  after a nice tutorial here at FOSS4G2016, i've been installing
grass 7.0.4 on my Mac (as an x11, "normal" unix app, rather than as
/Applications/...).
there were various hurdles (many involving the fact that macosx tends to
suppress passing on the environment variable DYLD_LIBRARY_PATH,
presumably for security reasons).
my last (known) problem gave me symptoms similar to
https://trac.osgeo.org/grass/ticket/3057
this seems to come from wx-2.8-gtk2-unicode/wx/lib/plot.py, where there
is the following code:
# Needs Numeric or numarray or NumPy
try:
    import numpy.oldnumeric as _Numeric
except:
    try:
        import numarray as _Numeric  #if numarray is used it is renamed Numeric
    except:
        try:
            import Numeric as _Numeric
        except:
            msg= """
            This module requires the Numeric/numarray or NumPy module,
            which could not be imported.  It probably is not installed
            (it's not part of the standard Python distribution). See the
            Numeric Python site (http://numpy.scipy.org) for information on
            downloading source or binaries."""
            raise ImportError, "Numeric,numarray or NumPy not found. \n" + msg
i guess new versions of numpy don't contain oldnumeric.  i solved this
by installing the python Numeric package.
sorry if this isn't the correct place to report bugs/hopeful-solutions.
cheers, Greg Minshall
