[GRASS-user] new addon for multivariate surface interpolation from sparse points with smoothing
Sajid Pareeth spareeth at gmail.com
Thu Aug 25 16:24:31 PDT 2016
Hi Markus
Thank you for this excellent addon.
I was testing it with some trmm data, and getting this error with default
"thin" value of 1.5.
ERROR: knn: inserting duplicate
Then if I increase the thinning factor, it works, but the algorithm thinned
out quite a lot of points.
Any lead would be helpful, thanks
Regards
Sajid
On Thu, Aug 25, 2016 at 9:02 PM, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> The new addon v.surf.tps performs multivariate thin plate spline
> interpolation of sparse points with smoothing. If you ever wondered
> why worldclim data (http://worldclim.org) follow so nicely elevation,
> the reason is multivariate thin plate spline interpolation of
> meteorological station data with elevation as a covariate. The module
> can also be used for gap filling of remote sensing data, e.g. MODIS
> LST reconstruction of cloud-covered areas, after fine-tuning the
> module's parameters. The module works only with GRASS 7.2+.
> Markus M
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160826/ad484d57/attachment.html>
