[GRASS-user] vector attribute calculation in grass python
Moritz Lennert mlennert at club.worldonline.be
Tue Aug 30 02:17:16 PDT 2016
Dear Alassane,
Please keep conversations on the list.
On 29/08/16 19:49, alassane toure wrote:
> Dear Moritz,
> I am a newbi in python programming.  Following your instructions i added
> the followings..
> par_sqf=[]
> c_number=[]
> pchng=[]
> but pchng stayed NULL for all rows (see below)!
You set pchng = range(len(par_sqf)),
but par_sqf is only defined as a Python variable by
par_sqf=[]
so it is normal that it is NULL.
Don't mix up Python variables and vector map column names.
If you want to set the attribute column pchng to contain a value that is
equal to the length of the value of the attribute column par_sqf (i.e.
count the number of digits (plus decimal point) in the area value), then
you have to use v.db.update:
v.db.update map=parcel column=pchng qcol="length(par_sqf)"
Although I don't understand what the sens of such a length would be.
Maybe it would be easier if you explained us what you are trying to do,
instead of only how you are doing it.
Moritz
