[GRASS-user] --exec interface not working with a script
Markus Neteler
neteler at osgeo.org
Tue Dec 6 11:10:58 PST 2016
On Dec 6, 2016 7:47 PM, "Vaclav Petras" <wenzeslaus at gmail.com> wrote:
> On Tue, Dec 6, 2016 at 12:27 PM, Markus Neteler <neteler at osgeo.org> wrote:
> > TODO: how to find GISBASE? must be defined
> but I still don't understand. What is the issue with that? GRASS Python
modules don't need to check or directly use GISBASE and this is the same
case.
Ok good.
> Does the code in the example run? (It runs for me.)
For me only when running in the source code directory (but I never use
"make install").
If the example is reasonable then I'll complete the backport and remove the
comment.
Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161206/a8e2dcf8/attachment.html>
