[GRASS-user] Grass: Finding depression from contour
    Ivan Marchesini
    ivan.marchesini at gmail.com
    Sun Dec 11 05:29:16 PST 2016
There is a useful addon for this: r.geomorphon .
An alternative can be also
r.param.scale
Best
Ivan
Il Dom 11 Dic 2016, 13:22 Markus Neteler <neteler at osgeo.org> ha scritto:
> On Sun, Dec 11, 2016 at 5:01 AM, Faisal Kabir <faisal.kabir at gmail.com>
> wrote:
> > Hi,
> > I've labeled contour (DEM) map using d.vect. Now I would like to find the
> > depression [contour with low elev value are inside the contour of higher
> > elev] automatically. I can view it in the Map display window which is
> > tedious as I've to zoom in and out for several times.
> > Is there any method available in GRASS?
> Yes: in r.fill.dir for example.
> I have taken your question as motivation to add an example to the
> manual page and updated it on the GRASS GIS Web server right away:
> https://grass.osgeo.org/grass72/manuals/r.fill.dir.html#examples
> It shows how to run sink-filling and how to identify the filled areas.
> Please note that filling depressions is not needed nor desired when
> calculating watersheds with r.watershed in case that this is your
> scope.
> Best,
> Markus
> Markus Neteler
> http://www.mundialis.de - free data with free software
> http://grass.osgeo.org
> http://courses.neteler.org/blog
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Sent by smartphone
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161211/9a234203/attachment.html>
