[GRASS-user] Fwd: r.modis.download error
    Gianluca Massei
    agr.gianluca.massei at gmail.com
    Sat Dec 31 05:54:57 PST 2016
I'm tryng to use r.modis.download but I can't get the data I need.
According with the module man page and pyModis docs, I've made a
setting.txt file with username and password for access in
https://urs.earthdata.nasa.gov, and i run this command:
r.modis.download -d --verbose settings=C:\Users\gianluca\Doc
uments\ModelliGIS\MODIS\MODIS_GRASS\SETTING.txt
product=ndvi_aqua_sixteen_250 tiles=h18v04 startday=2015-01-01
endday=2015-12-31
 after several minutes, I get the error message reported in atteched file
"output_command.txt"
I'm using GRASS 7.2.0RC2 (64bit) in windows 10 and in linux ubuntu 16.04
LTS
Could anybody help me, I can't undertand what I'm wrong.
Thanks in advance.
GM
Dott. Gianluca Massei, PhD
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161231/30d66fa6/attachment-0001.html>
(Sat Dec 31 11:09:15 2016)
C:\Users\gianluca\AppData\Roaming\GRASS7\addons/scripts/r.modis.download.py -d --verbose settings=C:\Users\gianluca\Documents\ModelliGIS\MODIS\MODIS_GRASS\SETTING.txt product=ndvi_aqua_sixteen_250 tiles=h18v04 startday=2015-01-01 endday=2015-12-31
Downloading MODIS product <ndvi_aqua_sixteen_250>...
  File "C:\OSGEO4~1\apps\Python27\lib\logging\__init__.py",
line 851, in emit
  File "C:\Users\gianluca\AppData\Roaming\GRASS7\addons/scri
pts/r.modis.download.py", line 248, in <module>
    sys.exit(main())
pts/r.modis.download.py", line 231, in main
    modisOgg.downloadsAllDay()
  File "C:\Users\gianluca\AppData\Roaming\GRASS7\addons\etc\
r.modis\downmodis.py", line 744, in downloadsAllDay
    self._downloadAllDaysHTTP(days)
r.modis\downmodis.py", line 760, in _downloadAllDaysHTTP
    self.dayDownload(day, listFilesDown)
r.modis\downmodis.py", line 722, in dayDownload
    self.downloadFile(i, file_hdf, day)
r.modis\downmodis.py", line 590, in downloadFile
    self._downloadFileHTTP(filDown, filHdf, day)
r.modis\downmodis.py", line 619, in _downloadFileHTTP
  File "C:\Users\
gianluca\AppData\Roaming\GRASS7\addons\etc\r.modis\downmodis
lDown, filHdf, day)
RASS7\addons\etc\r.modis\downmodis.py", line 619, in
_downloadFileHTTP
ileHTTP
  File
 "C:\Users\gianluca\AppData\Roaming\GRASS7\addons\etc\r.modi
r.modis\d
    self._download
a\Roaming\GRASS7\addons\etc\r.modis\downmodis.py", line 619,
 _downloadFileHTTP
day)
c\r.modis\downmodis.py", line 619, in _downloadFileHTTP
    sel
r.modis\downmodis.py", line 616, in _downloadFileHTTP
    "Retrying..".format(name=filDown))
line 1585, in error
    root.error(msg, *args, **kwargs)
line 1175, in error
    self._log(ERROR, msg, args, **kwargs)
line 1268, in _log
    self.handle(record)
line 1278, in handle
    self.callHandlers(record)
line 1318, in callHandlers
    hdlr.handle(record)
line 749, in handle
    self.emit(record)
line 939, in emit
    StreamHandler.emit(self, record)
line 879, in emit
    self.handleError(record)
line 802, in handleError
    None, sys.stderr)
  File "C:\OSGEO4~1\apps\Python27\lib\traceback.py", line
125, in print_exception
    print_tb(tb, limit, file)
69, in print_tb
    line = linecache.getline(filename, lineno, f.f_globals)
  File "C:\OSGEO4~1\apps\Python27\lib\linecache.py", line
14, in getline
    lines = getlines(filename, module_globals)
RuntimeError: maximum recursion depth exceeded
