[GRASS-user] Warnings installing some r.stream addons
César Augusto Ramírez Franco caesarivs at gmail.com
Mon Feb 1 08:33:07 PST 2016
Hello dear list
I'm trying to install all the r.stream addons, but some of them are
printing warnings, I'm using grass 7.0.3 from the ubuntugis PPA in Ubuntu
14.04.3
The output is:
Fetching <r.stream.segment> from GRASS-Addons SVN repository (be
patient)...
Compiling...
stream_vector.c: In function ‘create_sector_vector’:
stream_vector.c:44:9: warning: ‘c’ may be used uninitialized in this
function [-Wmaybe-uninitialized]
       c = NC(d);
stream_vector.c:43:9: warning: ‘r’ may be used uninitialized in this
       r = NR(d);
stream_vector.c: In function ‘create_segment_vector’:
stream_vector.c:256:5: warning: ‘c’ may be used uninitialized in this
   c = NC(d);
stream_vector.c:255:5: warning: ‘r’ may be used uninitialized in this
   r = NR(d);
Installing...
Updating addons metadata file...
Installation of <r.stream.segment> successfully finished
Fetching <r.stream.slope> from GRASS-Addons SVN repository (be patient)...
Compiling...
main.c: In function ‘main’:
main.c:201:23: warning: ‘out_min_curv_buf’ may be used uninitialized in
this function [-Wmaybe-uninitialized]
   out_min_curv_buf[c] = calculate_min_curvature(cur_row, c);
main.c:264:12: warning: ‘out_min_curv_fd’ may be used uninitialized in this
  Rast_close(out_min_curv_fd);
main.c:199:23: warning: ‘out_max_curv_buf’ may be used uninitialized in
   out_max_curv_buf[c] = calculate_max_curvature(cur_row, c);
main.c:256:12: warning: ‘out_max_curv_fd’ may be used uninitialized in this
  Rast_close(out_max_curv_fd);
main.c:197:23: warning: ‘out_gradient_buf’ may be used uninitialized in
   out_gradient_buf[c] = calculate_gradient(cur_row, c);
main.c:248:12: warning: ‘out_gradient_fd’ may be used uninitialized in this
  Rast_close(out_gradient_fd);
main.c:195:25: warning: ‘out_difference_buf’ may be used uninitialized in
   out_difference_buf[c] = calculate_difference(cur_row, c);
main.c:240:12: warning: ‘out_difference_fd’ may be used uninitialized in
  Rast_close(out_difference_fd);
Installing...
Installation of <r.stream.slope> successfully finished
Fetching <r.hydrodem> from GRASS-Addons SVN repository (be patient)...
Compiling...
hydro_con.c: In function ‘hydro_con’:
hydro_con.c:340:9: warning: variable ‘carve_to_edge’ set but not used
[-Wunused-but-set-variable]
     int carve_to_edge, skipme;
Installing...
Installation of <r.hydrodem> successfully finished
Should this warnings be ignored? Or should they be taken into account in
some way when using them?
Thanks in advance
*César Augusto Ramírez Franco*
Laboratorio de Sistemas Complejos Naturales
Escuela de Geociencias - Facultad de Ciencias
Universidad Nacional de Colombia - Sede Medellín
Teléfono: (57-4) 430 9369 - 300 459 6085
http://labscn-unalmed.github.io/
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160201/72a0de90/attachment.html>
