[GRASS-user] Retrieve projection's EPSG code
Helmut Kudrnovsky
hellik at web.de
Tue Feb 2 05:06:15 PST 2016
Panagiotis Mavrogiorgos wrote
> Hi,
> Is it possible to get the EPSG code of the active projection (if it
> exists)?
if the location was created by an EPSG code, e.g. in the location wizzard:
g.proj -p
-PROJ_INFO-------------------------------------------------
proj : ll
datum : wgs84
ellps : wgs84
no_defs : defined
towgs84 : 0.000,0.000,0.000
-PROJ_EPSG-------------------------------------------------
epsg : 4326
-PROJ_UNITS------------------------------------------------
unit : degree
units : degrees
meters : 1.0
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Retrieve-projection-s-EPSG-code-tp5248374p5248488.html
Sent from the Grass - Users mailing list archive at Nabble.com.
